Trailer light working only when door open
G
GRI
ny
I have not tried Trouble shooting the truck yet
Sent from my DROID RAZR HD using Tapatalk 2
G
GRI
ny
I went through all the fuses and relays related to towing. They are all there. Unless I test the relays if I knew how. I may try a switch relays
G
GRI
ny
There weren't any missing except for
#21 and 9 which have to do with the trailer tow battery charger. Which I didn't think had anything to do with my problem. I could be wrong.
Unless the relays are bad they are all there
aka grumpy car stereo guy
in your glove compartment ther is a package with a fuse and a relay. the dealer will not put those in for you. they must be inserted in the proper place to have your lights work.
G
GRI
ny
In any particular spot? I looked in the owners manual and and all the fuses I had to do with trailer lights in the break or all installed so unless there's a spot where it doesn't show on the owners manual then I don't know where it is
My truck is a 2010 and I think I'm the third owner
G
GRI
ny
Nothing in the glove box
G
GRI
ny
Swaped relay 38 and37 with 39 which is the upfitter relay and all was good. swapped out new 20 amp fuses and they were good. went home on lunch test of the plug and the plug on the truck tested it was working so I hooked the trailer up to it and all of the lights work now. must have been a bad fuse or relay connection or a gremlin.
G
GRI
ny
Thx for all the help guys I appreciate it
