Timbren rear bump stop kit
Guy
Anyone run these? I’m not looking for a $2000.00 Fox kit. A little extra security would be nice. Wondering how these compare to stock. They’re cheap enough...
G
Guy
And this kit is a bump stop replacement from what I can tell. This is not their towing kit.
A stronger progressive rate stop?
Skmon
Sanford, MI
Had a set on mine to pull a 23 lance travel trailer. Trailer would squat horribly without them. Worked very well towing, but did effect ride quality not towing. Pretty much sits on axle empty.
Bought a motor home will be pulling mine off.
Overall all they worked on my 2018
G
Guy
No.
You didn’t follow the link. You had their helper springs basically. Different product. These are bump stops. Not for towing.
Thanks
Skmon
Sanford, MI
I followed the link, read reviews, 1/2" from axle is not a bump stop, it stiffens up the ride.
Your money, I bought mine from Etrailer.
Mine are going into the garbage can next oil change.
brettmess24
What do you want/need these for? What is your intended use?
Camburg just came out with a bump relocation mount to be used with deaver or Icon leaf packs...Icon also has a kit. Basically just an extension and you re use your stock bump pad. SDHQ also makes a nice kit and that would be the kit I would use if I did not have the SVC kit with Fox ifp bumps.
If using your truck hard off-road there is no replacement for a good bump kit from SVC, RPG or Icon.
I would never use timbrens for anything jmho
G
Guy
This reviews are just for Timbren products in general. Not for the bump stops. Do me a favor? Do you have your original order? Look up the part number? I want to see if it’s the same.
Thanks
