Ticking or clicking noise on hard accelerations
Recently, I noticed only on Wide open Throttle, I hear a clicking noise, sounds like a bad CV joints…. boot or something clicking, at the beginning it was only a click or 2. I first thought it was little stones getting thrown out to the metallic side step, that is exactly how it sounded when it was one or 2 clicks…. but now it sounds like a click click click click….. but again only when I push the gas pedal really hard.
This happens on 2WD so I think the front axles are not connected to the wheels.
Do you guys have any idea where to look ?
perry
What you’re describing sounds exactly like what my boosted gen 1 does with 89 octane under hard acceleration and is pre detonating…..
V
You might have a vacuum leak, monitor it. Also could be that check valve above your master cylinder for the iwe's.
I also noticed that my Turbo gauge does not go all the way at Full Throttle. It only goes up to 3/4 or something.
I think it should go all the way to Max when at full throttle !
Is it related to the vacuum leak ?
