Those with skid plates (foutz, Ford Performance, RCI
WC_Raptor
California
I've got the one with a short nipple so there is a white plastic fitting that goes on the hose and the fitting clips onto the valve itself. I think I've got a 3/8' ID hose for what that's worth.
You'll see what I mean on the oil filter drain once you see your truck. The forward Foutz plate (between the LCAs) is solid and doesn't have a hole like the stock one that aligns with the second (toward the rear) drain from the plastic oil filter drip pan. Not a big deal just put a little catch pan up in there and pull the filter like normal and you'll be good to go. Good luck.
policedutchdog
California
I need to add one of these drain plugs to make it less of a mess next oil change. Which Fumoto plug one works the the best. The F107N?
