Third member change.
9.75" is a conventional axle, it doesn't use a 3rd member. Which means you would need to have the Ring & Pinion professionally installed, you can't just swap out the center section.
jimmyjamm
Bend, OR
If you are good with changing gears, same process as a removable 3rd member, you just gotta do it under the truck. With a gauge stand and time, you can do it easily enough, but if under warranty it will void all of the warranty on the rear end.
