Supercharger and Behind Bumper Winch
Discussion in 'Ford SVT Raptor General Discussions [GEN 1]' started by Gotbitn, Mar 29, 2014.
  1. Gotbitn
    Gotbitn Full Access Member
    93
    16
    Jan 29, 2014
    Don't have my truck yet but when I get it I want to Whipple supercharge it and install a behind the bumper winch.
    Does anyone have this combination?
    I am curious if the winch and regular or oversized heat exchanger with fans will fit. If it did fit did it require any modification?
  2. Biggest
    Biggest FRF Supporting Member Supporting Member
    877
    1,113
    Jul 2, 2013
    So many questions...
  3. boomer
    boomer Full Access Member
    57
    16
    Dec 4, 2010
    my truck has all of that. fits no prob. i have the ADD stealth fighter bumper
  4. Gotbitn
    93
    16
    Jan 29, 2014
    I probably should have indicated that I want to keep the stock bumper.
  5. Rookie
    Rookie Supporting Vendor Supporting Vendor
    9,764
    3,582
    Dec 16, 2012
    Fort Wayne, IN
    Don't the heater exchangers go in front of the radiator? With a hidden winch mount the winch would be in between the bumperettes.
  6. Gotbitn
    93
    16
    Jan 29, 2014
    Yes the heat exchanger goes in front of the radiator.
    Looks like the regular HE will fit, might have to relocate the winch control pack though.
    The upgraded HE, not sure, even with relocating the winch control pack. The upgraded HE looks to be almost twice as tall, it is also thicker with the fans.
  7. Yeti
    Yeti Member
    Nov 14, 2011
    Valley Center, CA
    I have a 2011 Raptor SC with a Roush Phase 2 SC. The heat exchanger is installed behind the grill but in front of the bumper which seems to be standard. I had 4 Wheel Parts try to install the ADD Venom winch bumper with a winch but the HE was in the way. I called ADD and they said you need the HE Relocation kit AC01151003 to move the HE out of the way. The only problem is they discontinued this part. I am looking for anyone that has this kit that can supply the install guide, or specs so I can fab out something.
  8. NE Ford
    NE Ford Full Access Member
    518
    285
    Dec 9, 2014
    Southern California
    I've got a hidden winch in my stock bumper and it's a pretty tight fit. Perhaps if you changed the mounting on the HE you could make it work. I can snap a few photos of you want to see the space.
Share This Page
