Spongey brakes
menerso
2019 Raptor SCREW
Maple Grove, MN
Does anyone else think that they have really "spongey" brakes? I understand all cars are different but I almost seems like air in the lines. I have a 2012 with under 1000 miles on it.
Do you think I should go back the dealership?
Squatting Dog
Kansas City, MO
I had a 2011 and 2012 and both of them lack in brake department. Lot of people swear by upgraded brake lines on FRF.. I haven't done it, it is on the list..
-Greg
BDRAG
HAhahaaaa.
Dallas area
Mine were fine till I used them ALOT last month at the Raotor Run. Amazing how antilock brakes work in the off road. I know I was chattering them 80% of the time. They went soft. I am headed to the dealer in the am for a look at my coolant leak at the intake neck and hose. I am having them look and bleed the brakes and make the **** poor A/C work better. Think its a fresh air / heat duct issue.
If they have time I will get the drivers heated seat fixed and the non working rear window defog and no lit switch for that along with the intermittent door switches for windows on the drivers door. Although since we BEAT THE SHIT out of our trucks last month I have not had to rap the door briskly to roll up my windows! HAhahaaaaa. I know there are a few more items on my list. Hummmmm.
BDRAG
kawie95
Manhattan Beach, CA
Mine have pulsating of the pedal a little ever since I had it. I just try to go easy on it when on the street. Try washing the rotors, sometimes brake dust can make them not work as well. A clean car is a happy car :)
menerso
menerso
2019 Raptor SCREW
Maple Grove, MN
Mine work like I have to pretty much stand on them to get them to grab well. It makes sense about the aftermarket brake lines... less expansion. I hate bleeding my brakes... damnit
kawie95
Manhattan Beach, CA
Try driving a 69 Cadillac coupe deville for a week. That will make you plan braking blocks ahead. Worked for me, I am MUCH easier on my brakes now on the road. I cruise and coast to my stops. Also use manual shift mode and downshift a bit.
If you still have issues, see the stealership
dawing
Try doing 3-4 60-30 in the ABS stops with lots of cooling in between each session.Do not....I repeat do not come to a full stop until the brakes have completely cooled or you will leave a hot spot on the rotors.If you are doing it right you should smell a hot brake pad smell.Make sure you cool in between each stop or you will boil the brake fluid. Brake like your dog just stepped in front so make sure you secure loose objects.This is how you bed in your pads and rotors.Results if done right are immediate.
P.S. check your rear view first.
Maxx2893
Rock and Roll Offroad
Burleson, TX
Thanks for the info. One question though, is this for new brakes or like mine that are spongey but have 32,000 miles on em.
