Some Cobb engine dress up installed today (+Cobb Intercooler)
Shark
Frisco, TX
I installed the Cobb radiator shroud, overflow tank cover, and the snorkel bracket on the new Gen3 this evening. This is mostly just engine dress up, although the snorkel bracket does prevent a potential air restriction issue. Pretty simple install that took under an hour in total. Here is before and after:
COBB Tuning
Austin, TX
I just did mine the other week but my air intake sits up a little higher now. Is this an issue? @COBB Tuning
You're good! If you want, you can loosen up the hardware holding the shroud and snorkel tie-down and wiggle the lip of the snorkel farther towards the front of the vehicle and the shroud back a little bit. That should get it to lie flatter.
tm965
NOVA
curious if anyone has seen their intake temps drop after installing the shroud
hingedthinker
Phoenix
I did my Cobb Stage2 just last week. Hoping to complete logging and send to Goose today. :) I did the shroud too. Much better than the plastic junk. I also need to install the TS eBoV. Looking good. I noticed the battery is positioned differently in #JenTres compared to JenToo.
