Roush cat back fitment
TheTip247
Kansas
Anyone had any problems with the fitment of the Roush cat-back? Mainly the tailpipe/tips? I just installed mine and the tailpipe angles down about where the Y pipe for the tips connects. This makes the tips hang below the bumper more than I like and then the tips arent straight. (Ive shoved the exhaust up as high as that back hanger that you bolt on the rear spring support would let me.) And one tip is straight and the other kind of points off to the right. I've messed with them trying to get everything to line up and I just cant get it. WIth all this, I also had a problem with the mid pipe after I cut it to length. Cut it and went to slide it in the muffler and the pipe diameter was just big enough it wouldnt fit in the flare of the muffler. I took the other end I cut off and it slid right in the flare, WTF! Ended up having to have a muffler shop run the mid pipe through a straightener and then it fit just fine. I just get a junk kit or what?
hungerforraptor
Hartford, CT
I have the Roush catback installed and my Y-pipe does point down slightly. I don't like that it does that either. I guess they did it like that to make sure its not touching the bumper. But both of the pipes are straight on mine. Didn't have any other fitment issues like you're describing..... And I haven't heard of anyone else with those issues either, so yeah you may have gotten a bad kit.
Don't know what the customer service is like but give them a call see if they'll send you a new Y-pipe
DesaRaptor
I had mine installed using the existing bend over the axle so it would exit the side.
RangerRob
Ramona, CA
I've had a few fitment issues with mine similar to what you have described. The rubber part of the hanger that attaches to the rear spring mount tore out so I purchased a better hanger from an exhaust shop and welded the new one on and pushed it up further. Before the tips were about 3 inches from the bumper and now they are only an inch. I believe the ****** hanger the Roush supplies with the kit may be your problem. You can get a better one from just about any muffler shop for about $25. Hope this helps.
Rob
T
TheTip247
Kansas
Rob
Thats the way I want mine to fit. Nick from Roush just contacted me today about this thread and wanted some pics. Hopefully he can shed some light on this.
Wrong Way
Rob
Looks good!
T
TheTip247
Kansas
Quick update...
First off I would like to thank Nick from Roush that trolls this board. He went out of his way to get ahold of me on here after he saw this thread. He got some info from me and pointed me in the right direction to get this resolved. Im currently waiting for a new "Y" pipe to show up to see if that resolves some of my issues.
Nick at Roush and Stage 3 Motorsports (where I ordered the kit from) have been very helpful and have had good customer service thus far. Id do business with them again in a heartbeat if the need arises.
robbys3m3
That's great to hear about their customer service. I just installed they're cai and catback, and am overall happy. We had similar issues with the exhaust install, but nothing that we couldn't get past in a few minutes. I too agree that the y pipe makes it hard to align the tips straight. Mine are close, but i am going to play with them more as i feel the tips look like they are at a little different angles. Regardless, the exhaust sounds great and I'm happy with everything and would buy again.
Reptar
Jersey
Mine fit great, but I do wish the tips sat closer to the bumper. Mine are a little over an inch away, wish they were tucked up 1/4" away to maximize ground clearance.
robbys3m3
Quick update...
hi there,
have you been able to install the new y pipe yet? if it helped the fitment, i may be inclined to request one also as the more i look at my tips, the more id like them to fit a little nicer...thanks!
