Rear Winch ideas?
ZAGA
San Diego
Hey folks,
I just got 19 SCREW couple weeks ago and i intend to trailer my car to tracks with it.
I am looking for a winch idea that can be portable or not to be mounted in rear. It can be mounted in bed, rear hitch mount... anyone have done such a thing?
I looked at some of the double hitch solutions but they do not have trailer capacity of 8k lbs.
Thanks in advance
Loufish
Burbank CA
Can't speak for this forum, but I've read several articles about mounting a winch mounted on a square tube to be used in the hitch, and a mount for storage in the bed when not being used...
Z
ZAGA
San Diego
i been looking and can not find anything solid. I rent uhaul auto transport so even i can mount the winch on it is OK for me..i mount it, use trailer then remove it.
Have any links you can share?
Z
ZAGA
San Diego
Z
ZAGA
San Diego
Just buy a hitch mount and put a winch in it.
* Here's a hitch mount: https://www.harborfreight.com/hitch-receiver-mount-for-winches-69106.html
* Here's a winch: https://www.harborfreight.com/5000-...-with-automatic-load-holding-brake-68144.html
Those are not the only options...just google "winch hitch mount", buy one, and then buy a winch...problem solved!
thank you for the links, so you are suggesting to decouple the trailer then hook the winch and pull car on then hook the trailer back?
Ski4Ever
Denver, CO
I'm not suggesting anything, just giving you an idea for the rear hitch mount that you mentioned you were looking for. :)
I don't know how you would keep the trailer from moving if it wasn't connected to the tow vehicle while you were trying to load another vehicle on it...
Z
ZAGA
San Diego
:) clear
but yea my worry is what you think as well regarding the trailer moving/tipping etc.. during the load/unload.
so my problem is still unsolved :)
Ski4Ever
Denver, CO
Without knowing what the uhaul trailer looks like to see how you'd mount anything to it, I don't know that there's any way we can recommend a winch mount that would attach to the trailer. And I definitely haven't heard of a truck bed mount for a winch, though I suppose it's possible it exists if you want to drill through and attach to the frame rails. :eek:
Silly question, I'm sure, but how have you loaded the car onto the trailer in the past? Or have you not done it before? Can you not just drive the car onto the trailer?
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
It's only pulling a car rolling in neutral up onto a trailer. Hardly any load really. Sorry I just read you mentioned this option in the first post. I'm not being very helpful so far. Lol.
Once you get the car strapped in you could remove double hitch again.
Z
ZAGA
San Diego
Do you think the upper receiver tube on those double receivers is rated for the force from the winch pulling on it? Plus, neither is rated to 8000lb, like the OP said he's looking for.
Yea i looked at those and called up CURT yesterday and they do not recommend to put a winch mount on the accessory port and winch 3500lb car..the tech guy said the weld might snap.
Z
ZAGA
San Diego
Here is a link of the Uhaul auto transport trailer
https://photos.app.goo.gl/7A29Wmq7CQfCn97f7
thanks all for the suggestion and help..much appreciated
Ski4Ever
Denver, CO
Yeah, I figured you wouldn't want to put a winch on that upper hitch receiver.
ahhh now this is something i will think about..do not mind doing this muscle work :)
I think it's probably a good solution for you...it will be more physical work than just pressing a button for the winch, but is MUCH easier for you to use with a rented trailer, and it will be much cheaper. Once you get your own trailer you can look into mounting a winch on it in a more permanent/secure manner than anything you'd be able to do with the Uhaul trailer.
Good luck! I hope it works out for you!
Loufish
Burbank CA
Now I got it....
I'd fab up a special hitch to go into the truck with small section of female square tubing to accept any normal hitch...and fab a quick release mount for the actual winch...the trailer would be hitched up and the winch would be temporally mounted to pull cars up the trailer...after that you disconnect the winch and put it away...
Remember to use good copper cables running from the battery up front to a quality quick connector in back to power the winch...
101,329
60,419
clong18
