Raptor wiring project 2.0
Discussion in 'Ford Raptor Lighting Modifications Forum [GEN 1]' started by sj-CHI, Apr 26, 2017.
Sponsored By: KC HiLiTES
  1. sj-CHI
    sj-CHI Full Access Member
    73
    90
    Feb 11, 2011
    Chicago Suburbs
    I recently completed a fairly large (by my standards) wiring project on my 2014 Raptor and along the way documented the process, parts, and learnings I went through.
    This project got started when like many of you I got frustrated with having too few auxiliary switches for the lights and accessories I have on my truck. I also wanted to do some custom wiring features that would take some engineering and lastly my plan was to allow for expandability.
    I decided on the Bussmann RTMR Fuse and Relay box as the base for my new system. It's a great foundation for fuses and relays that offers lots of expansion and customization. I found a resource online that builds boxes with all the accessory and switch wires ready to go. After receiving the box I ended up tearing it apart and starting from scratch. Nothing against the person that built it, in fact the work was very high quality, I just wanted to do it different and upgrade some of the accessory wires to 10ga. This required me to purchase a bunch of specialized tools and materials to re-build the fuse box. In retrospect I should have built the fuse and relay box myself from the start and I would have saved some money.
    I developed a wiring plan to accommodate all my accessories (sorry about the rough PowerPoint drawing).
    1. Front D2s -- clear
    2. Front D2s -- Amber
    3. Front light bar (top)
    4. Front light bar (bottom)
    5. Hood lights (just added these, D-SS Sideshooters)
    6. Rear bumper lights
    7. Rear facing lights above bed (Amber)
    8. Bed cargo lights (new)
    9. Compressor
    One of the functions I planned was a strobe feature that would allow me to strobe my front hood lights and rear facing amber lights (above the bed). I wanted to be able to hit a switch that would allow the strobes to fire even if the hood and rear lights were off. Additionally, I wanted the same switch to work if either or both of the lights were on. For this I turned to Able Manufacturing and purchased two of their SHO-ME modules. I got in touch with Able and they helped tweak the wiring to meet my requirements.
    The whole fuse box and various connections needed to be waterproof so I decided to use Metrics’s-Pack 280 connectors. I picked up some good tips from a guy who documented his own build and put a ton of detail into the process (DIY Bussmann RTMR Fuse Block, Part 1 – Introduction | Bodenzord). The connectors would allow me to remove the whole Bussman box fairly easily if needed.
    I needed a way to mount the fuse box in the truck. I wanted it under the hood but didn’t want to interfere with any other truck functions and I wanted a clean install that could be removed if needed. I built a mock up of the bracket first in cardboard and then out of wood. My brother in-law had his company turn the wood mock up into a 3D CAD document that could be taken to a local fabricator. He found a shop that could fab the piece out of aluminum and powder coat it for us. The end product is a very clean, strong but lightweight mounting bracket that gets bolted to the battery box.
    I finished up the Fuse box build, mounted it to the new bracket and started adding ground busbars and a fuse holder for the master fuse. Note: all the small Metri-pack connectors are crimped, soldered and finished with adhesive lined heat shrink for durability.
    The switch harness and connector for under the hood is completed.
    Early on I decided to use a 6 position switch plate and chose one from Crown Offroad. I like the overhead location for the switches and I was able to source a solid red switch for my strobe function that would fit cleanly in the Crown plate. Finally I needed to find a momentary switch that I could use to change the strobe pattern. Initially I wanted to incorporate that in the red strobe rocker switch (off - on, momentary). Maybe this type of rocker exists but not int the form I wanted. I opted for a small bullet push button that I mounted to the right of the switch plate.
    Finally time to install the whole build in the truck and finish all the connections. I made up 4ga battery cables and ground connections for the frame and negative battery terminal and bolted my setup to the battery box. I taped into the passenger seat fuse box (fuse 34) for a switched power source and dremeled the cover to allow it to all close up.
    The end product took longer than expected and I know there are cheaper ways to accomplish what I built but I had a plan that I wanted to see through and the challenge was fun! Next project…..
  2. J DAMAGE
    J DAMAGE Full Access Member
    833
    453
    Jul 15, 2012
    NJ
    Great job, clean install, I did the same. Using the battery box to support my bracket on my set up.makes it so much easier staying under the hood.
  3. Mikerider
    Mikerider Full Access Member
    105
    108
    Jun 20, 2016
    Very nicely done!
  4. M3toSVT
    M3toSVT Full Access Member
    33
    218
    175
    May 27, 2015
    Great job! Meticulously thought out and well executed.
  5. tossty
    tossty Full Access Member
    69
    21
    Apr 6, 2015
    Puerto Rico
    That is well done, congratulations. :favorites13:
  6. FN-2187
    FN-2187 Full Access Member
    29
    101
    237
    Dec 10, 2015
    Bay area, CA
    one hell of a job. funny you posted this, I was just looking for some ideas on other forums when I came across this thread. Not sure if its too much to ask, but is there any way you could PM me what you ordered as far as terminals, plugs, etc? Id like to do a similar setup with my raptor.
  7. sj-CHI
    73
    90
    Feb 11, 2011
    Chicago Suburbs
    Yeah no problem. I kept a spreadsheet with all the materials with part #'s I used. Happy to PM that to you.
  8. The258
    The258 Full Access Member
    794
    541
    Feb 18, 2012
    McAllen TX
    Can you make another and say I purchase it off of you? :D
    FarFromStock likes this.
  9. M3toSVT
    33
    218
    175
    May 27, 2015
    Just post it up. I would be interested as well.
  10. sj-CHI
    73
    90
    Feb 11, 2011
    Chicago Suburbs
    I wish I had the time but it was a one off project for me. I would reach out to LVJ Motorsports / @Kmandoske. He builds great kits that are complete and ready to install.
Share This Page
