PLEASE NOTE: This image does not depict the 6 lug rotors for the Raptor
R1 Concepts ELINE SERIES BRAKE DISC WITH SILVER ZINC CORROSION RESISTANT COATING
When price is important and quality is essential. R1 Concepts ELINE Series Brake Rotors offer many of the benefits of an OEM part at a fraction of the cost.
- Cross-Drilled and Slotted Design
- Drilled holes provide maximum air circulation for increased cooling
- Holes are countersunk which reduces heat build up
- Exclusive R1 Concepts Diamond Slot increase brake pads bite
- Diamond Tip use as indicator for brake rotor wear
- Military Spec Plating for rust protection
- Direct Fit OEM Replacement Brake Rotor
- Double disc ground finish reduces rotor vibration
- Meet Or Exceed OEM Standards For Excellence
- Mill balanced brake rotors ensures long lasting durability
- Brake rotors are casted using G3000 graded iron.
The R1Concepts Catalog does not list enough parts to look up Ford F150 Raptor Applications so FRF Members need to contact me directly for vehicle specific applications, orders and member savings.
CLICK HERE TO CONTACT ME ABOUT APPLICATIONS, PRICING & QUESTIONS
