6.2 Pictures of installed SW exhaust
cdurbin
Lebanon, IL
Ive searched the forums and was unable to find anything.
Im installing a SW exhaust that exits behind the rear wheel on a SCREW. Unfortunately I cannot get the tails to exit correctly. No matter how I orientate the exhaust, one tail wants to exit lower. If I attempt to twist the pipe it either hits the other one or binds inside the end bracket. The only way to remedy this is to remove the rear hanger all together.
So if anyone can take some quick shots of their exhaust Id appreciate it.
This picture shows what Im referring to.
Corey
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Brando
NW New Jersey
I had SW install mine so I am not sure of the specific ?'s you have but hope the pics can help.
Sent from my DROID RAZR using Tapatalk
Brando
NW New Jersey
Sorry for the same pic twice. Let me know if there is any other angles you need.
C
cdurbin
Lebanon, IL
By chance, could I get a shot of the mufflers. Specifically on the exits.
I'm not sure what's up with this. I've tried flipping the mufflers, rotating them so they're at a 45* angle and everything. I just CANNOT get the tips to sit anywhere near as high as yours.
Brando
NW New Jersey
I have noticed that too about the tips. I will get you them tomorrow
Brando
NW New Jersey
Good luck and Merry Christmas! I will be by the truck all day so let me know if ya need more.
Stainless Works
Chagrin Falls, OH
After viewing the pictures it appears to be just more adjustment, level the mufflers and start from there to adjust the tails. Once the system is level the tails will line up. Use the last hanger/clamp assembly as a pivot point.
Rakimb17
SoCal
Do you guys have x pipes or is it straight through? I have two straight pipes coming from my headers and was thinking about using an x pipe instead. And I had to drop the spare tire during install. It was just barely in my way.
