It looks like the bumper is 2 parts? If that's the case I'd only need the left side. I looked at the parts diagram and that's what it appeared to be
Wow that had to be one heck of a hit. Mine has been rear ended twice and backed into a brick wall (not by me) and is not damaged that bad. I have thought about replacing it with an aftermarket but haven’t yet. I suggest putting a hitch in the receiver, as most of the damage will then be done to the other vehicle.It looks like the bumper is 2 parts? If that's the case I'd only need the left side. I looked at the parts diagram and that's what it appeared to be
I have a quote from 2021 for just over $1400 installed for an oem rear bumper without the sensors that I see on yours. I’d expect yours to be considerably higher.They literally hit that left side only so even a hitch wouldn't have helped unfortunately. Not sure how much insurance is quoting for the rear bumper if I did an after market rear I'd need to do a front as well to make it match , not sure I wanna spend that money right now
USAA should have my quote soon and I will go from thereI have a quote from 2021 for just over $1400 installed for an oem rear bumper without the sensors that I see on yours. I’d expect yours to be considerably higher.
For what it’s worth, I have an ADD front bumper so they don’t match and for the protection value I won’t be doing a rear dovetail. I do, however, consider the factory bumpers to be the least aesthetically pleasing part of the Raptor. In my opinion, Ford didn’t apply enough thought to the look of the bumpers.
Does that come with the gray color like factory? Or will I need to get it painted to match ?My '16 superduty had a 2 piece bumper as well. Take the insurance money, and buy this as a temp replacement. Then replace with a Dovetail later.
Step Bumper For 2009-2014 Ford F-150 Rear Powdercoated Black Fleetside/Styleside | eBay
Styleside, For Models Without Rear Object Sensor Holes. Built with steel for lasting strength and style. Interchange Part Number 9L3Z17906CPTM, FO1102375 Prop 65 Warning WARNING: This product can expose you to chemical which is known to the State of California to cause cancer and birth defects...www.ebay.com
