Mid perch why?
Coolhand5599
Why set to mid perch? I have read ans researched this but I didn't see anything on why you would do this. What are the pros and cons?
Deleted member 12951
Guest
It raises the front end and levels it out from the factory rake. Gives you some extra clearance. Tightens up the steering some. Plus there is peer pressure.
ZBoater
My understanding was for additional clearance. But some years don't like having that done to them, which makes me very skeptical of doing it to mine.
Huck
Chicago Sw Burbs
I did mid for about two weeks. The ride was miserable as was the bump steer, where I worked the roads sucked and the truck literally would bounce across an intersection when turning.
Went back to stock and bought 3.0"s
pat'sRAPTOR
Everywhere
That's not correct that's top perch you're thinking of. The 2012 and newer raptors don't do well at all on top perch
