JD Squared BEAST Notcher
JDSquaredInc
Johnson City, TN
Beast Notcher
The Beast is the ultimate in hole saw tube notching. Able to easily handle straight notches, offset notches, angled notches, and notches in bends.
The weight of the BEAST notcher is 50 lbs. This helps with the chatter and saves longer on your hole saws.
List Price - $499
Features:
* Capacity of 3/4" to 3" OD
* Angles up to 50°
* Can offset notch up to half the tube diameter.
* 1" Ground & Polished Stainless Steel shaft
* Double sealed needle bearings.
* Clamps allow you to notch on a bend.
* Requires an ordinary 1/2" hand drill
As well Ford Raptor Forum members receive 10% off orders. Use Coupon code Raptor on our website JD Squared, Inc..
---------- Post added at 12:58 PM ---------- Previous post was at 12:57 PM ----------
raptrcrzy
What kind of hole saw bit would you use for maximum life in this jig?
JDSquaredInc
JDSquaredInc
Johnson City, TN
I wouldn't use anything to special. Just use bi-metal hole saw blades. The key is speed and feed using the 7-11 second rule. Don't cut quicker than 7 seconds cause you can burn up the hole saws and don't take longer than 11 seconds for the same reason. Doesn't hurt to spray something on the hole saws to keep down the heat and friction.
JDSquaredInc
JDSquaredInc
Johnson City, TN
We are offering a discount for all FRF members. For any orders you place with us you will receive 10% off the order. If you are wanting to order either use the coupon code Raptor online or give us a call 423-979-0309. Thanks!
JDSquaredInc
JDSquaredInc
Johnson City, TN
JDSquaredInc
JDSquaredInc
Johnson City, TN
JDSquaredInc
JDSquaredInc
Johnson City, TN
Ok here is our Black Friday Special! All purchases online will be 10% off the items on the order. As well each order with either a bender or notcher will receive a JD2 T-Shirt which is limited to one per customer. When placing the order put the size shirt you are wanting in the comments. Keep in mind the shirts do run small. Sale begins 11/28 and end on 12/2. Thanks in advance for your orders!
