JDSquaredInc
Beast Notcher
The Beast is the ultimate in hole saw tube notching. Able to easily handle straight notches, offset notches, angled notches, and notches in bends.
The weight of the BEAST notcher is 50 lbs. This helps with the chatter and saves longer on your hole saws.
List Price - $499
Features:
* Capacity of 3/4" to 3" OD
* Angles up to 50°
* Can offset notch up to half the tube diameter.
* 1" Ground & Polished Stainless Steel shaft
* Double sealed needle bearings.
* Clamps allow you to notch on a bend.
* Requires an ordinary 1/2" hand drill
As well Ford Raptor Forum members receive 10% off orders. Use Coupon code Raptor on our website JD Squared, Inc..
---------- Post added at 12:58 PM ---------- Previous post was at 12:57 PM ----------
