Installed Rigid 40 and whelens in front
nsdq3
West Point, VA
Where did you get the whelens and what did you get them for if you don't mind. I am in the market for some to fit on the outside of my plate
Txfight00
Txfight00
Scottsdale,AZ
Yeah that front mount is well made. Only issue I'm having is that no matter how I try to adjust, the whelens angle slightly up. Did you have to bend the lower lip of the bumper opening a little to get the lights to point flat?
Txfight00
Txfight00
Scottsdale,AZ
Honestly didn't even look to see if the lower tabs could be removed. Popped out the grille insert and thought it was good. Will have to pull out the lights and check it out. Thanks!
Vash
OK, USA
You'll need to either bend or cut the lower grill tabs as they interfere with the fit of the lights. I'll probably end up with a similar setup. Recently had more Micro and Nano Pioneers installed. Just need to add a 40 or some Whelen Dual Slimlines behind the grill.
