nikhsub1
So, I've upgraded all my speakers and added an MTI behind the seat sub box with an amp for the Sub. Sure it sounds better than stock but it should sound WAY better than stock. In my limited knowledge on the subject I understand to get the best sound I need the NavTV unit and a 5 channel amp. How is the Nav unit actually hooked up to the system? I'm a dummy so if you can be explicit it would help. Now the amp, how does that run into the system? Do I need to run new wire to all the speakers? Do I need the 5 channel amp AND a separate sub amp? What 5 channel amp would you recommend?
I don't need an award winning system just one that doesn't sound so muddy. Also, how to you tune the Nav device? Where is the best place to buy it, I see people are saying it's $450 ish but I only see it for $550 ish. All info is really appreciated.
