Think im going to try the rpg shackles first, why not add something that provides a lil extra function ASWELL as help make the truck look better...
guessing its going to be awhile before someone comes out with some new springs for the front coilovers
just goto ff the phone with RPG, they have the shackles ready to ship, just need the damm truck to put em on!!!
I've got that kit on my Gen1 and honestly a bumpstop kit should be priority #1 if you're gonna go run offroad. I had a 6-8" gravel bar in a wash ruin my day and bend my frame. Compression travel at ride height isn't that much and all you need to do is find a bump that will exceed that available travel and bang, you're into the bumpstops and the frame with the axle.
That's why jumps don't bend frames unless they are extreme. You get to use all of that advertised travel to allow the shock to slow the axle down. Whereas that seemingly small bump in a wash will bend your frame because you're working with less than half the travel left.
If you're set on RPG, just call and have a chat with Corey, he's super knowledgeable and he'll make sure you're setup right.
