Check Brake System Warning
SaintsFan
Louisiana
So I’m driving on the interstate going 75MPH on adaptive cruise control and out if no where I get a “check brake system” warning on the dash. I pull over, restart the truck and began to drive again. Then it happened again about ten minutes later. Brakes seem to be working fine and everything seems normal otherwise. Anyone know what could be causing this?
jerkstore
Northern VA
Mine does the same. I have figured out it is only when I use cruise control at 65-70 mph plus. I am going to replicate it before next service and take to dealer.
Qnardacci
Try pulling the battery cable off for 10 seconds.
Control Alt delete the computer.
wheelman55
Big Bend or MN
Happened to me in the first week of ownership. It was an easy fix:
http://www.fordraptorforum.com/f260/2018-check-brake-system-56814/
