Captain CABO
- Joined
- Feb 7, 2013
- Posts
- 97
- Reaction score
- 23
I've been trying to diagnose an issue I'm having with my AUX 1 switch. I've had my AUX 1 running a Baja Designs 37" OnX bar for the past year with no issues at all. Last Saturday during a pretty rough run through some washout sections of Havasu desert I noticed my lightbar was off. Sure enough, fuse 18 (30 amp) was blown. I put a new fuse in, everything worked fine and I went on my way.
Fast forward to two days ago. I go to flip on my bar to blind a Prius that wasn't moving at a light (far more effective than the horn) and nothing worked. Went under the hood and the same fuse was blown again. This time when I went to go put a new fuse in it pops instantly. Here's where I'm having issues. I disconnected the light bar and disconnected both the connections under the dash (yellow to red wire) and under the hood but I'm still getting power to the fuse slot. With nothing on in the truck, key in my pocket, I am getting power to the fuse slot where Aux 1 should be.
I know this means I have something hot in the truck but I just can't figure out where it could be coming from. All the connections I have made are sauntered and heat shrunk over and I've been over every inch of wire and through every light connector I have put in. The wires to and from the fuse box in front of the motor are all bundled in the factory loom so I can't see where there would be an issue in there. All my other AUX switches are working just fine, it's only AUX 1 that's being a bitch.
Any help with this would be appreciated. I called Ford but it was a waste of 10 minutes.
Any ideas?
Barrett
Any ideas?
Barrett
