Auto stop eliminator
JD06
Florida
Gents,
not sure if anyone is aware of this product. Just giving everyone a heads up. This is a plug and play option that allows you to turn off the auto start-stop and keep it off. It will stay off until you hit the button and turn it on putting it back into it's normal function mode. Watch the videos the install is straight forward and not difficult, took me about 15 min.
https://www.autostopeliminator.com/
dew.man
se michigan
IMHO well worth the price of admission. The dash switch and functionality remain available but the truck remembers the last setting. Much cleaner option than disabling battery management through Forscan or using a trailer plug.
And no, I was not compensated in any way for my endorsement lol
Sent from my SM-T820 using Tapatalk
Livernois Motorsports
Michigan
Yes if you do not feel like turning it off every time you can program it for an easier use. We have a programmer that will tune it for performance or tow. It does have the ability to disable start stop option for you. Now it also has the ability for you to data log and view gauges. Very easy touch screen programmer that anyone can use. If you have any questions call us at 313-561-5500 my name is Jake thanks.
https://www.livernoismotorsports.com/product/LPP631148
df4801
Or just pull the trailer light plug under the steering wheel and save $100
Takes 2 seconds and can easily plug back in if you ever hook up a trailer. No down side at all.
don't know why anybody would otherwise want to switch back and forth. Stop-and-go is either a function you love to have on or you love to have off
Johnkn
LaPlata, MD
Not sure why anyone would want to rip apart all that when they can spend $99 on a module that plugs into the ODB2 and disables the start/stop in 10 seconds, then can toggle it back on if needed...
jabroni619
I'm still baffled that this feature is the single most talked about subject on here while at the same time having the most options to "fix" one of which is available stock, which is the button.
GCATX
King Dingaling
Central Texas
Because it's a stupid concept to start with? Obviously, it's a minor annoyance, never the less, I always forgot to mash the button. More nanny BS.
docskeet1
Athens GA
What he said.
Cost = $0.00.
Easily reversed.
