GEN 2 Audio system doesn't working
Alimalik
I just bought new 2017 Raptor 2weeks ago , since yesterday I am trying to turn on my audio, mean cd, radio, or settlite radio but it won't work,
What should I do ? Is there any salutations or should I take to the dealer?
solarwinds
DFW
just no sound ? or screen blank ? ya dealer. if just no sound u mighta hit the mute button on wheel
Alimalik
Alimalik
well I can see all other things working but the audio is off I tried to turn ON but it won't work I can't go in to the audio Source,
Are you using a MyKey (fob)? Try with the other or a different key if you are.
MyKey is set up on the menu and I thought I remembered seeing audio restrictions as part of the options.
If you have a paired bluetooth device, turn the truck off; then the bluetooth device, then power the truck back on, see if that works. Sometimes Sync3 likes to refuse to respond to audio input, it’s a s/w bug.
Two last things to try - a factory reset (of sync3), pull battery power for a few minutes and reconnect.
If none of that works, take it to the dealer.
Alimalik
Alimalik
Wow, now my audio start working again,
You told me to disconnect the battery for few minutes and I did the same after i hooked up the battery again and start the raptor everything start working again thanks for the tips and believe me if any of you have any issues with the raptor this is the plate form to resolve it
