GEN 2 Android Auto - SYNC 3 - Can't answer phone - SOLUTION
DarthKickA55
Tennessee
Hay all -
Not sure if anyone has had this problem but thought I would share a quick solution since it took 2 months to resolve.
I use Android Auto exclusively and have on all my Ford's in the past. For whatever reason I could not answer the phone when in Android Auto. I could make calls, but to answer them I had to quickly unplug my phone (exiting android auto) and answer on the screen. Incredibly annoying.
I had been hoping a software update would fix it, but no joy.
After some digging I found a solution that worked.
Without the phone plugged into the USB, on the main screen for SYNC 3, do this:
go to: Phone - Set Phone Ringtone - Use phone ringtone.
Viola! problem solved.
Braaaaptor
Starbucks Enthusiast
The drive-thru
Seems android auto has a unique glitch or quirk for everyone. My current gremlin is a loud echo on the oppostite line only present if someone calls me.
Sync dial out = no echo
Sync recieving calls = no echo
AA dial out = no echo
AA recieving calls = echo
I'm going to try that setting and see what happens, thanks!
DarthKickA55
DarthKickA55
Tennessee
I get the echo both dialing and receiving but only occasionally. I usually hang up and call the person back and works fine (usually).
Fordraptorrrrrrrr
Idaho
Well DarthKickA55 that seems to have worked, I just went into the settings like you said and I checked the Use Phone Ringtone, not sure how that was different from before but hey it seems to have worked so far. Thank you. I've had this issue for months and everytime someone would call me it would ring and I'd hit the answer button and it would be silent. Then I'd have to hang up and call them back. So glad it's fixed.
