All The Way
This past Friday was the second round of short course racing, under the lights and during the fair. My plan was to go out and put a good run in and not go big. After losing some time sliding my way through the mud hole I stayed on the gas a bit too long heading up to the table-top. I checked up some, but it was not enough. Instead of down siding I launched my self to the moon... OHHH SHIT! The pro trucks were landing where I did!!! The run put me in first till the third round when I reset TQ for the night. The RPG Stage 2 bump stop kit and frame support did their job. The drivers front inner fender liner is out. I just bought some new plastic rivets to fix it. The weight of the tire gate caused a whole new set of issues...see pictures. Steering wheel is off center to the right a bit, but it doesn't pull. I knew the toe was out so the lower control arms just moved in a different direction this time. My dual band antenna is shot, broke the upper half off. The fuel door came off, it was ok. Conclusion: I was stuck on stupid for that run. Things to change: New rear springs and mid perch in the front. Put the alignment cams in and get it squared away.
Videos:
Big Air - F150 Raptor Short Course Off Road Racing 7/27/12 1st Round - YouTube
Big Air - On Board Video - F150 Raptor Short Course Off Road Racing 7/27/12 - YouTube
F150 Raptor Short Course Off Road Racing 7/27/12 2nd Round - YouTube
F150 Raptor Short Course Off Road Racing 7/27/12 3rd Round - YouTube
Broken antenna
Springs hitting the frame brace
U-bolt impact in this picture
Gap between bed rail and frame
Back edge warped in
It moved!!
Pass side, you can see its bent
Drivers side. No damage.
I might have hit it a second time after I pulled the inner fender out
Yep... One tire front landings will do it every time.
I was ok with the box being tweaked.. then I saw the cab got hit. Grrrr
Grill smacking things.
Videos:
Broken antenna
Back edge warped in
It moved!!
