Amber lights and Forscan
KryptosXLayer2
Charlotte, NC, USA
Sorry I get ******* award... car has to be in gear... anyway, it's working but with the turn signals as well, any way to just get the halos without the turn signals? TIA.
Code:
DRL - Parking Lights only (stock LEDs only)
BCM
726-26-02	x1xx	xxxx	xxxx
726-50-01	01xx
My question is, when you compare these two, I have noticed this difference:
Code:
DRL - Parking Lights & Turns only
BCM
726-45-01	xxxx	7Fxx	xxxx
726-50-01	08xx
Is 726-45-01 the code for the turn signals, and more importantly, is 726-50-01 the code for the brightness of the halos? If:
726-50-01 01xx = "dim" brightness for the halos, running it without turn signals when combined with the exact same 726-26-02 x1xx xxxx xxxx code on both, then 726-50-01 08xx could be the bright code for the halos
NOTE - I have NOT tested this, I'm just saying what I'm seeing here. The Parking Lights & Turns only codes make the halos brighter than the Parking Lights only codes, and this is the difference I've noticed in the codes. I will not be the first one to try this, I'd like to get @Livnitup 's opinion of this before we break something!
nikhsub1
Los Angeles
Well the 26 module is the same for both... maybe that turns off the head lights? The 50 module is either 01 or 08, maybe brightness of the turn signal? The 45 module is the perplexing one to me, what is the stock value for 45? Or maybe 45 is the turn signal?
StrangeRaptor
Park City, Utah
I implemented this today - but I could not get it done in the advanced settings. I was able to change 726-26-02 x1xx xxxx xxxx, but when I tried to change 726-50-01 01xx - it said it was an incompatible setting and refused to save. I had to go to the "easy" approach and set the DRL to "1 None" to get the headlight to turn off. That tells me that the 726-50-01 setting is the headlight on/off. I have a 2018 Screw, so not sure if it is a year issue.
