BlackMamba
My truck, on mid perch, has alignment issues. Too much negative camber and too much positive caster. This is the case even though the LCAs are pulled all the way in, front and rear, on both sides.
Current #s are -1.0 camber both sides and over 5.0 caster both sides. If the tech tries to get the caster within spec, the camber goes out of spec, so we just focused on getting the negative camber down. Truck drives ok.
The alignment I had done in early 2011 after I initially went to mid-perch had the camber at -.7 and -.5 and the caster at 3.8 and 4.2. Unfortunately, I never looked, but I don't think the lower arms were pulled all the way in at that time.
So obviously something is now out of whack. Based on some PMs with members on the forum, discussions with the mechanic that installed my RPG stage 3, discussions with ICON, etc., it would seem the two weak points that may be damaged are the spindles and the UCAs. It is my understanding that members and vendors on this forum have seen a fair number of bent spindles.
I have had the front suspension inspected by Ford Service and they said that they did not see anything wrong. But it is my understanding that the spindles and UCAs will not necessarily "look" bent so this was probably a worthless exercise.
My mechanic quoted me $550 to buy new spindles and replace them. Seems fair, but that is a lot of money to spend to only end up with a pair of used spindles and the same alignment issues.
Here is a photo of my passenger side spindle. Distance between top of spindle and tire is 1", maybe a little less. Difficult to measure up there. Driver side is about the same. Truck is mid perch, stock wheels, stock BFGs inflated at 40lbs or so. I have always understood the stock set up to be tight, but is it this tight? Or could my spindles be bent at the top towards the wheel? If anyone has the same set up and could weigh in it would be greatly appreciated.
It is also my understanding that a really good off-road suspension shop can actually diagnose spindle issues just by getting the truck on an alignment machine. Not sure how this works. But can anyone in Houston make a recommendation for a shop with this skill set.
Any other way to diagnose the problem?
I am looking to spend $ on some other mods for the truck, but want to get this issue figured out first.
Thanks in advance for any help.
