37" Tire/Wheel combos - whats working
Tanner Case
Atlanta, Ga
I'm running RPG 2.25" collars on stock beadlocks, nitto ridgegrapplers 37x12.5. I'm sitting 1/2" higher in the front, minor front fender liner trimming. No rubbing at full lock, looks great & overall happy with setup. By adding more preload the front feels harsher on small bumps.133ab422217251e1aec70db5f3257822.jpg8409c47252458ae53cfb8277bb0a5459.jpg87c21a6c42681ddc47a933e069aa520e.jpg
Sent from my SAMSUNG-SM-G920A using Tapatalk
Looks perfect! Have this exact setup coming next week. Did you have the shop do the trimming or did you do it yourself? How much trimming was required when you say "minor"?
apeezie289
Been a while since I posted on here. Since I put this photo up we removed the honeycomb plastic just behind the fender liner, also folded over the pinch welds, then re-installed the fender liner. This eliminated all rubbing.
Mr Gunny
29 Palms, Ca
I’m running 37x12.5’s with 2” leveling kit. No rubbing but my speedometer is now off about 5+ miles per hour at higher speeds. Dealership said they can not recalibrate. Any one know how I can fix this problem??
TXRaptor
nGauge tuner allows you to change the tire size, which solves the Speed-o issue. Pretty sure you can do it with Forscan, as well.
93,190
56,469
ngodavid23
