2018 Raptor purchase advice
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by ShadyRaptor, Feb 15, 2020.
  1. ShadyRaptor
    ShadyRaptor Member
    Feb 14, 2020
    California
  2. 911 Crazy
    911 Crazy FRF Supporting Member Supporting Member
    590
    297
    Jul 23, 2019
    Maine
    Wow, good to see you're in no hurry.
  3. joegie
    joegie Full Access Member
    284
    71
    Feb 27, 2017
    North San Diego
    there was a tsb on 2017 and early 2018's to check the shift linkage, i assume that's what that was for.
  4. Tin Can Rap
    Tin Can Rap Full Access Member
    160
    74
    Oct 27, 2018
    Pennsylvania
    Or reprogram the TCM; had the TSB done to my 2018.
  5. metalwhiz
    metalwhiz Member
    30
    15
    Sep 9, 2018
    AZ
    Looks like an earlier 2018 model. Probably has plastic oil pan, which might not matter to you.
  6. ShadyRaptor
    ShadyRaptor Member
    Feb 14, 2020
    California
    Thanks guys!! good Info.
  7. Jraptor78
    Jraptor78 Member
    5
    Dec 14, 2019
    Iowa
    You gotta test drive and look them over before you buy. I was gunho for a 2017 with 17k in miles went to check it out and body had little scratches everywhere, bumper had a dent, on the test drive the check engine light came on and the rear axle had a nice light coat if surface rust already. Checked out a 2018 with 40k in miles the truck was like it was new. My conclusion some Raptors are rode hard and put away wet some are driveway trophies you want the later of the two. That's my 2 cents.
    GCATX and Troutrad like this.
  8. WooPig
    WooPig Full Access Member
    66
    48
    Jun 18, 2019
    Northwest Ark
    I bought new so didn’t have to worry about some of the stuff but one thing to consider is towing or hauling large amounts in the bed. The payload and towing capacity is considerably less on these trucks than anything else in the class. If you pull anything of size it’s something to think about.
  9. Troutrad
    Troutrad Full Access Member
    297
    143
    Jan 24, 2020
    Kalispell, MT
    Agree with all of the above. Definitely must lay eyes on it and drive it. Before I bought new, I found one that looked pristine on the website and had every bell and whistle. First owner was a chain smoker. The smell had permeated every fiber in that thing. Just never know.
  10. Badgertits
    Badgertits Full Access Member
    959
    520
    Jan 24, 2019
    Ma
    true but a set of leaf springs can fix that- and they can tow/haul a lot more than a gen 1.....
    difference is when you’re exceeding capacity on a standard 1/2 ton you’re not simultaneously destroying $$$$ shocks & the comfy ride that goes w/ em
Share This Page
