2014 Wiring Diagram
nwporter
Does anyone know the wire color under the kick plate for the dome light? I am trying to install the door sills from recon but cannot seem to locate the right wire. I found the 2013 one and that is not the correct wire. Ford was no help either. Any help would be appreciated.
Thanks
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
2013 and 2014 are the same.
drivers door. green/purple passenger kick black 26 pin plug. pin 9
front passenger door. white same plug pin 5.
both are a normally closed circuit negative trigger
here, on frf
no. those tested as constant. both of them.
as far as the dome light wire, i listed the door trigger wires. the dome light wire is grey/purple positive trigger at the bcm. 12 pin plug. pin 1. the puddle lamp is purple positive trigger black 26 pin plug pin 1.
