GEN 1 2013 Raptor Rear end fluid change
JAQ51
Laguna Beach, CA
I recall seeing posts saying friction modifier is not necessary in our electronic lock differentials. I intent to swap my fluid and wanted to confirm to NOT use friction modifier in my rear end, correct? 25k miles with a mag-hytec cover.
Dealer swears manual calls for it.
B E N
Frederick, CO
You will know as soon as you open the differential, friction modifier smells absolutely foul. If it doesn't smell like a rotting skunks carcass that has been dipped in sewage, slathered with deer **** then perfumed with Durian fruit it probably didn't have friction modifier and won't need more.
Forum consensus is that it is not required. The E-locker does not use Limited slip plates.
Ruger
Northern Nevada
I cast my vote for B E N to be hired by Fox News!!!
B E N
Frederick, CO
I'm not sure if I should be feel offended or complimented, I don't really follow news, only TV i have is Hulu and MTOD.
