2010 F-150 Lamp Replacement Guide
MagicMtnDan
Magic Mountain
Found this Auto Lamp Replacement Guide (using OSRAM Sylvania products) and thought it'd be a good reference if you're considering swapping lights out for LEDs or if you need to replace any of the lights.
Speaking of LEDs, here's a site offering a wide range of LED products:
http://www.superbrightleds.com/cgi-...sp=/1157.htm&gclid=CPih3cTA2aICFRNubAodWk5vyA
From the Sylvania website:
Certain bulbs are available for sale at the SYLVANIA Online Store. New bulbs will be online for purchase in the coming weeks.
When two or more lamps are listed for the same application, remove the lamp and check the numerical designation.
2010 FORD F150
High & low beam headlamp
H13 (9008)
H13ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H13XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
Parking light
3157NA
Front turn signal
3157NA
Rear turn signal
4057
4057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
4057
Stop light
4057
High mount stop light
921
921ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
921LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Fog/Driving light
9140
License plate
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
921
Front sidemarker
194
Rear sidemarker
4057
Map light
194
906
906LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
578
578LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
6411
6411LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Trunk/Cargo area
921
____________________________________________________
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
Link: http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/AutoLRG-Results.htm
Members online
93,202
56,485
bjorn-dpc
