Z7What
- Joined
- Apr 8, 2010
- Posts
- 108
- Reaction score
- 102
:shock1:FOR SALE:shock1:
2003 Ford F-150 Larait Supercrew FX4
Miles: 97,*** on Body - 30,*** on Motor
Interior Mods
Wayne2003 Ford F-150 Larait Supercrew FX4
Interior Mods
Auto Meter Complete Replacement Cluster
Auto Meter Pillar Pod
Auto Meter Fuel Pressure Gauge
Auto Meter Vac/Boost Gauge
Auto Meter Oil Pressure Gauge
Auto Meter Steering Wheel Pod
Innovate XD Series Wideband
Kenwood DDX7015 Double Din TV With Navi and Rear View Camera
2 - 300/2 JL Amps and 1 - 500/1 JL Amps Custom Mounted In Expedition Console
6.5" MBQuart Components Front and Rear
2 - 10" MQuart SQL Subs In Custom Back Wall Box
Clarion TV Molded Into Rear of Expedition Console
BattCap 300
Video Amp with 4 Outputs
Clifford 3.5 Alarm with Auto Start and Window Roll Up and Down(Needs a Remote)
20% Tint on Front Windows and 20% Over Factory Tint on Rear Windows and Rear Glass
Handle Cups, Window Swtich Panels, Radio Bezel, Top Of Console, Rear of Consoul and Panels on Custom Sub Box Painted Dark Shadow Grey
Exterior
Reflexxions Cowl Hood
Shaved Door Moldings
Shaved Larait Strip
Shaved FX4 Decal
04 F150 TailGate Embles on Fenders and Tail Gate
White Fast Emblems Front and Rear
03 Harley Grill
Depo Clear Fog Lights with 3000K(yellow) HIDs
Clear L Corners With Sylvania SilverStar Bulbs
Sylvania Xenarcs HIDs
L Led 3rd Brake Light
Smoked Tail Lights
Line Of Fire LED Brake Light
Soft Bed Cover
Ford Rubber Bed Mat
Cut Stock Antenna
Navi Chrome Antenna Base Cap
3" Body Lift Tow Hitch( Its designed for trucks with Body Lifts)
15" Drop Hitch
Line X'ed N-Fab Running Bars
Suspension
6" Fabtech Suspension Lift
3" Body Lift
Torsion Keys
5" Rear Blocks
ProComp Tractions Bars
Rancho Steering Stabilizer
Dana Spicer Pitman Arm
Moog Upper and Lower Ball Joints
Moog Inner and Outter Tie Rod Ends
TA Rearend Cover
Rotorpro Slotted Only Rotors with Hawk HPS Pads(Will Include NEW Front Slotted Only Rotors)
4.56 Yukon Gears
4 - Bilstein 5150 Shocks
Stud to Eye Shock Conversion
Lightning Rear Sway Bar with Custom End Links
20x10 Cruise Alloy Wheels(Starting to Pit a Little)
38X15.50XR20 Toyo Open Country M/T
Performance/Underhood
2003 Ford Lightning Motor From #2005 Lightning
4# Lower
Home Ported Throttle Body
Home Ported and Custom EGR Deleted Plenum Painted Dark Shadow Grey
Ported C&L Elbow Painted Dark Shadow Grey
L&S Oil Separator
90MM MAF
MAF Air Filter Adaptor
K&N Filter
Metco Aux Pulley 100MM
100MM Idler Pulley
Gator Back Belt Motor and Blower
Flex-a-lite Monster 270 Electric Fans with New Style Controller
JLP Street Reservoir
AFCO Single Pass Heat Exchanger with 2 6.5" SPAL EFans
Killer Chiller
Factory Tech Shift Plate
Factory Tech Tranny Cooler with 8" SPAL Fan
Tranny Lines Bypassing the Radiator
Not Front Cats Y'ed Into Single 3.5" AeroTurnine 3535XL Diesel Muffler Out the Side with a 4" MBRP Tip
255LPH Bosch Fuel Pump
TUNED BY WES @ TPSPERFORMANCE.COM
331RWHP/411RWTQ
I am sure i am leaving alot out, if i remember anything i will add it to the list as i remember!
ASKING 20,000 OBO!
Whats not perfect: Needs a windsheild, Wideband needs to be recalibrated or new sensors, Small small dent in rear bumper, small hardly noticable dent in front bumper, right rear top part of door has a super super tiny dent with chipped paint(touched up), hood has small chips in it(touched up)
The only think i may not include with the truck is maybe the Aeroforce gauges! If it will not work in my Ranger i will include it as well, waiting to hear back from Aeroforce to find out.
BattCap 300
Exterior
Shaved Larait Strip
Shaved FX4 Decal
03 Harley Grill
Smoked Tail Lights
Soft Bed Cover
Ford Rubber Bed Mat
Cut Stock Antenna
15" Drop Hitch
Suspension
3" Body Lift
Torsion Keys
5" Rear Blocks
TA Rearend Cover
4.56 Yukon Gears
4# Lower
L&S Oil Separator
90MM MAF
K&N Filter
100MM Idler Pulley
Killer Chiller
331RWHP/411RWTQ
ASKING 20,000 OBO!
