1989 Foxbody Mustang LX. Rebuilt with 5k miles. Asking 22.5k
Richiemitchell
Virginia Beach
For sale is my 1989 Mustang LX Hatch. Located in Virginia Beach. I purchased this car in 2015 in very good shape. It was a perfect platform to start the build I wanted. The car was stripped down completely and professionally cleaned and rebuilt. Every bolt was run through the parts washer or sandblaster if necessary, every nook and cranny was sanded and repainted. the motor was completely broken down and rebuilt with the intention of building a reliable daily driver with enough power to put a smile on your face and break the tires loose through third. This is not set up to be a drag car and if you're looking for that I would recommend starting on a different fox that doesn't have this much work into it. This car is set up perfectly to be a very powerful daily driver or occasional weekend cruiser. Have not had it on the dyno recently but before the major overhaul, it was making about 300rwhp and 340rwtq. Overall, I would say the exterior is a 9/10, the interior 9/10, and the drivetrain is 10/10. I am happy to answer any questions and send photos or videos to interested buyers.
Build List to the best of my memory is as follows. (Maybe missing some smaller mods)
Motor:
Ford Performance GT40x Aluminum heads-64cc Chamber
Comp cam stage 4 extreme energy XE274HR
Ford Racing Lower and Upper intake manifold
24LB injectors
Comp cams timing chain
Ford Racing chrome valve covers
Performance Distributors Livewire Dynamod Distributor
Performance Distributors Livewires 10mm Spark Plug Wires
BBK 70mm throttle body
BBK cold air intake
BBK mass air meter for 24lb injectors
Screaming Demon ignition coil pack
Ford Racing high flow oil pump
ARP oil pump shaft
1.6 pedestal mount roller rocker arms
Aluminum Ford performance main, cam, and connecting rod bearings
Re machined factory crankshaft
Ford Racing performance Gasket engine rebuild kit
Smog pump eliminator kit
Fan shroud kit
Aluminum 3-row performance radiator
Electric radiator fan
180-degree thermostat
BBK underdrive pulleys
Polyurethane motor mounts
Optima red top battery
Drivetrain/Suspension:
McLeod Street Pro Clutch- Rated to 450WHP
B&M Short throw shifter
Hurst competition shifter handle with white knob
Ford Racing Aluminum driveshaft
3.73 Ford performance Gear kit
polyurethane transmission mount
SR performance Clutch Adjuster kit
Slotted and vented front brake upgrade
Eibach Front and rear sway bars- Red
Koni STRT Upgraded rear shocks
SR performance weld on subframe connectors (not installed but will come with car)
Exhaust:
BBK Longtube Headers
BBK catted H pipe
Flowmaster American Thunder Catback exhaust
Appearance:
Cervini 2.5in Cowl induction Hood
SVE 17x10 Deep Dish anniversary wheels (Rear)
SVE 17x9 Anniversary Wheel (front)
BF Goodrich Gforce comp2 tires
Hood pin Kit
Ultra-clear headlights
Pro Comp Shift light
Mechanical oil pressure, fuel pressure, and water temp gauges
25% window tint
I am sure I am missing some parts here but this gives a good look at how much work has gone into this Foxbody build. I love this car and would love to hold onto it for 20 years and watch it go up in value every year but the time has come part ways due to life’s circumstances. I would love for this car to go to another enthusiast.
Title in hand ready to go
Feel free to reach out about anything related to the Fox.
My number is 7348373735
Regards,
Richie
