I'm running Pro Comp Series 1079 Polished Alloy Wheels with a -19 off set with Pro Comp 35x12.50R-17 Radial Xtreme AT Tires. At mid perch there is no rub however like another poster mentioned here, this set up will kick a lot of dirt/water splash making cleaning a chore. The stance is aggressive (about an inch further out than stock). I recently removed them though and put my stock set up back on after I plasti dipped them black and really like the look, not to mention the reduced road noise while driving on the BFG's.
I would recommend that you think about it before pulling the trigger or if possible ride with someone that is running M/T's, it really is a lot nicer with the stock BFG's. The 35's aren't that much different in size so either way should work for you if you are on mid perch, it will just be a question of availability in size from the tire/manufacture that you select.
There is a lot of good info on tires out there (so far I think the R/T's might be a good compromise as they are more aggressive than the A/T's and less than the M/T's), so do some leg work and you will more than likely be happier with the choice you make.
Good luck!
