Idle shake
Nex
RIP CoronaRaptor
Washington State
Need more information on your truck than the problem you are having. Idle should have zero effect on your brakes.
Sounds like 2 problems. Rough idle and warped rotors. But need more information.
thegrays
thegrays
Arlington, Texas
What are these trucks most common issue that causes a rough engine or mechanical issue idle
FordTechOne
Detroit
There are many possibilities. However, the engine creates the vacuum that the power brakes use for booster assist. A vacuum leak can cause low engine vacuum, which results in a rough idle and poor power brake assist (stiff pedal).
thegrays
thegrays
Arlington, Texas
I’ve gotten CEL p06b6 ever since that happened everything in the truck has gone downhill, brakes, alignment, idle shake, rough transmission downshifts and up shifts, and bumpier ride. Really it started when key would not start the truck said something about ignition failure. Used valet key and it started but since then it’s had numerous issues and failures
