thegrays
At idle engine (or maybe other failure) is shaking and causing brakes to be shaky and bumpy.
What are these trucks most common issue that causes a rough engine or mechanical issue idleNeed more information on your truck than the problem you are having. Idle should have zero effect on your brakes.
Sounds like 2 problems. Rough idle and warped rotors. But need more information.
There are many possibilities. However, the engine creates the vacuum that the power brakes use for booster assist. A vacuum leak can cause low engine vacuum, which results in a rough idle and poor power brake assist (stiff pedal).What are these trucks most common issue that causes a rough engine or mechanical issue idle
Comments like this is why @FordTechOne is so valuable to this forum!There are many possibilities. However, the engine creates the vacuum that the power brakes use for booster assist. A vacuum leak can cause low engine vacuum, which results in a rough idle and poor power brake assist (stiff pedal).
I’ve gotten CEL p06b6 ever since that happened everything in the truck has gone downhill, brakes, alignment, idle shake, rough transmission downshifts and up shifts, and bumpier ride. Really it started when key would not start the truck said something about ignition failure. Used valet key and it started but since then it’s had numerous issues and failuresThere are many possibilities. However, the engine creates the vacuum that the power brakes use for booster assist. A vacuum leak can cause low engine vacuum, which results in a rough idle and poor power brake assist (stiff pedal).
