GEN 2 What wire is this tapped into? With pics
KODIAK
This is under the front passenger side fender, towards the front of the truck in front of the tire. I took a bunch of aftermarket wiring out from the previous owner, and this is what’s left. What’s that blue wire with a white stripe? Trying to see what it is, and if I can use the red wire since it’s tapped in. Thanks if anyone knows.
KODIAK
KODIAK
I don't think that is a factory harness that wire is tapped into. I haven't seen any OEM runs that have that plastic split loom on them. I think you would have to trace back those wires.
They split the loom open, there’s that black wrap around it that they opened. I’m racking my brain here…
KODIAK
KODIAK
Side note, if anyone wants this flasher I pulled out…it’s yours just pay shipping.
FordTechOne
Detroit
Being blue with a gray tracer, I suspect that it's the parking lamp circuit to the passenger side headlight. That wire tap is completely hack; it it pierces the wire sheath, which damages the strands and creates a path for water enter the circuit. Not only that, but the BCM is only designed to power the load of the factory lighting; adding additional load to that circuit will damage the Field Effect Transistor in the BCM.
KODIAK
KODIAK
I’ll solder it back together and wrap that loom back up. I don’t need anything spliced into the parking lights. Thanks guys I appreciate it.
93,202
56,485
bjorn-dpc
