Baja Designs S2 Sport flush mounts for reverse/rear lighting?
Cody Templeton
Des Moines, IA
Just got my Evil Offroad Banshee rear bumper in that has cutouts in it for the Baja Designs S2 lights. I've got Squadron Sport lights on the front bumper, figured I'd just get the S2 Sport in the rear to match. I would like to use them for reverse/area lighting since they will be on the back, thinking the Work/Scene flush mount would be the best choice and then pick up the reverse light kit harness for it. Thoughts?
C
Cody Templeton
Des Moines, IA
Went ahead and ordered the S2 Sport black flush mount lights in white with the work/scene pattern along with the reverse wiring kit. Figured it would probably make the most sense to go work/scene pattern since they are going to be used for short distance rear/reverse lighting.
dillard09
College Station, TX and Socal
I will eventually get some S2 or S1 for my backup assist someday. My windows are so dark that I need to roll down my window when backing up sometimes to see in the dark. I think a little extra light would help. I will be going with some work/scene pattern when I do.
C
Cody Templeton
Des Moines, IA
Yea, I'm the same way. Currently I have a VLED's license plate LED bar with some very bright reverse lights in the tail lights and it works pretty good, but I will be losing the license plate LED bar when I swap bumpers. I wasn't planning on doing bumper mounted lights, but the Evil Offroad Banshee bumper comes with cutouts specifically for the S2's. I just assumed the work/scene pattern would be the best bet for them since it's short distance and very wide angle.
dillard09
Gotcha. Yes i think the work scene will put the light closer to the truck and with wider pattern.
And you can't go wrong with Baja Designs stuff. My opinion its the best lights made. Im a BD *****!
C
Cody Templeton
Des Moines, IA
Yea, I have their Squadron Sports in both amber wide cornering and white driving/combo on the front and it's insane how bright they are, plus the quality of the build is awesome. For the size of the lights they also put out way more light than others. Most people don't understand why their lights are expensive, but it's also because they don't leak water and **** out after 3 months.
dillard09
Exactly. Their quality is top notch and they bright as ****. I tell everyone if you want the best you get BD.
Between my truck and jeep I have LP9s, Squadron Pros, S2s, Onx6+, and XL80s.
C
Cody Templeton
Des Moines, IA
For anyone wondering I ended up using these on the Evil Offroad rear bumper. The bumper ends up mounting the lights on the inside of it to protect them, so you actually don't use the outside cover part. I choose to use the work/scene lenses in clear to get the best short distance lighting behind the truck for reversing. They're hooked into the reverse circuit, but are also wired to upfitter switch 4 so that they can be turned on any time. Definitely glad I went with them since I could no longer use my license plate LED bar.
93,202
56,485
bjorn-dpc
