GEN 2 Moldy interior smell
wiems
I could understand it if my interior got really wet, but it didn't. Any thoughts? Just started about 2 weeks ago.
GCATX
King Dingaling
Central Texas
Search for the "teen spirit" thread. Plenty of info there, I believe.
I had this issue. I took the cabin air filter out and sprayed coil cleaner through the open filter cover slot with the fan running. I did not re-install the filter.
Worked for me.
quikag
Dallas
Check to see if the front passenger side of your carpet is wet. If so, dealer needs to fix your drain line . Happened to my 2019.
W
wiems
Interesting. There is a wet spot UNDER the rubber mat, I cant see how water could have gotten under the rubber mat, so it must be a drain line. Where is theis drain line draining from?
K223
Florida
I second that. Happened to me, but caught it in time. There is a TSB regarding a drain line fix for the AC.
quikag
Dallas
Air conditioning compressor, I believe. Condenser drain line.
It’s amazing Ford builds almost a million trucks a year and can’t figure out how to route a drain line.
