Eibach springs
Paul-in-CA
hi,
I am about to do the same - did you guys do all the work ?
did you follow a members post or ?
I am looking to figure out what size tools are needed.
Thanks !
Paul
Badgertits
Ma
hi,
Thanks !
Paul
eibachs? Unless you LIKE working on your truck (& no knock on that) given that you went w/ eibachs over Geiser which saves you $250 or so I would 1000% recommend just dropping off @ a competent shop b/c regardless of how quick you could swap out yourself if you had all the tight tools you’ll STILL need an alignment after, & look @ it this way, the $$ saved w/ the eibachs over the geiser will cover it
Paul-in-CA
I agree with you Badgertits.....sometime much better to go have it done.
But....I sometimes like working on my toys. I do have a lift so that helps
K223
Florida
If you have a lift and a good spring compressor then your half way there.
CHMP
Santa Cruz
Yeah seriously. Make sure you also have a giant torque wrench, those lower shock mount bolts have to be insanely tight.
K223
Florida
Im betting most shops just hit it really well with a strong impact gun. Many guys who have worked on these trucks probably have a feel for it with there big gun. Would hate for this to come loose!
93,202
56,485
bjorn-dpc
