Installed s1 reverse kit?
NJDevil
NJ
Anyone installed this kit yet? Looks a bit different than the others I’ve seen, and a bit cleaner. Curious how it differs
Speeddeacon
NC
Looks to be a perfect application for the S1. Probably makes it easier to install than the S2 because you have more room to work with.
OffroadAlliance.com
Boston, MA
These S1's are consideribly brighter than the standard S2's in the Baja Designs reverse kit. And with a slightly smaller footprint, a bit easier to install. We're going to be including plenty of hardware with our S1 reverse kits that will allow the user to install multiple ways depending upon their desired placement.
We've also got our aux switch reverse wiring harness that is plug and play. This allows the lights to come on when the vehicle is in reverse or when you turn on the aux switch. Dual control that's plug and play, can't get much better than that! We've sold a ton of these and have had nothing but positive feedback. Bundle with a reverse kit and save $$$. In stock now, no waiting or lead times.
@NJDevil
We definitely think this is one great setup! Small but oh so mighty! And definitely tucks up and away a bit more than the standard S2 reverse kit.
NJDevil
NJDevil
NJ
@NJDevil
In stock and ready?!
OffroadAlliance.com
Boston, MA
Dammit should’ve ordered from you guys.
Well, yes. Yes you should have.
And for the rest of the folks out there, give us a call or order a set online! No waiting for S1's, S1 reverse kits and no waiting for our reverse light aux switch harness. All in stock!
Phone: 888-466-8991
Interwebs: OFFROADALLIANCE.COM
amREADY
Victoria, BC
@NJDevil
This sounds perfect.
Once connected to reverse, then it can't be toggled off, correct?
But you can use the Aux switch anytime.
OffroadAlliance.com
Boston, MA
Correct. This setup allows the lights to be triggered when the truck is in reverse as well as via the aux switch. If you only want the lights to be activated via the aux switch, then you simply omit the connection to the tail lights.
goblues38
STL
can these be flush mounted in the bumper if you were so inclined to cut the bumper?
