Power source for Rigid Radiance POD Lights
19PANDA
Boston, Ma
Is there a link for a full install like this, start to finish? I lost ALL SIX sets of my instructions I got like an idiot!
4x4TruckLEDs.com
Not sure which kit you got, but our SPP Triple Fog Light Kits include a harness that makes installation easy. The harness we provide with the Rigid Radiance has a 4th control wire for the back light. You can find those kits here: http://www.4x4truckleds.com/specialty-performance-parts/
Here is the manual for our SPP Brackets. Depending on the brackets you got they usually mount up the same to the same bolt areas so these MIGHT help you with your install:http://www.4x4truckleds.com/content/SPPManual.pdf
19PANDA
Boston, Ma
Thanks but I’m looking to wire it myself, was hoping to find a post detailing instructions on how to install with wiring instructions. Or a YouTube link if such a video existed.
4x4TruckLEDs.com
Welp wiring is not that hard. Positive/Negative for the RIgid and then there will be a postiive control wire for the back-light. Rigid uses DT connectors (2 pin) however on the radiance, it's just bare wires so you don't need to use connectors unless you wanna be fancy.
We do sell a harness if you wanna skip making it all. For the price, it's worth it. If you have Radiance you just cut the DT connectors off. The control wire is in there also: http://www.4x4truckleds.com/crystal...nectors-rigid-industries-kc-hilites-vision-x/
dudmleh522
AZ
Any chance this harness might fit Rough country lights? Plug looks pretty similar.
93,202
56,485
bjorn-dpc
