When you get out of the truck with keys.. does your truck lock?
sniperm
Hey, guys.. I just notice when I get out of my truck with my keys.. my truck makes a honk..but doesn't lock... I was about 20 foot away.. and my wife just opened the truck...
dude1782
PHX, AZ/SLO, CA
Is it running? When you get out of the truck with the keys and it's running it honks to let you know that it's running.
Sent from my 2017 Raptor using Tapatalk
dlbb
so cal
no that is the double honk thing. i disabled it via forscan.
it happens if you leave it on and leave with the keys.
there is an auto relock option also with forscan.
if you are interested in a list of what i recommend for forscan let me know. i even have a quick program list for it.
sniperm
sniperm
yeah.. when I have it running.. thought the honk was letting me know it locks..
---------- Post added at 09:20 PM ---------- Previous post was at 09:18 PM ----------
I heard about forscan..but kinda scared stealer would refuse to service my truck..
Dang... I thought it locked my truck.. I just walked into stores thinking it was locked all the time...
dlbb
so cal
lol the only one they may notice is the start/stop disable.
Auto Start/Stop Disable
Autofold Mirrors - Lincoln Style (see desc in Notes)
Double Horn Honk disable
Fake engine noise disable
Secure Idle enable
Panic Alarm
Stereo Extended Play
Engine temp & Transmission temp shows above gauges (8" Clusters only)
IPC Quick Boot (No Ford animation shows on cluster)
quick boot with engine &trans temp
DRL - Parking Lights only (stock LEDs only)
besides they have to prove a forscan change was directly responsible for a failure.
also this list includes the drl as parking lights. i did that for another owner. i don't need drl.
sniperm
sniperm
Secure Idle enable
Panic Alarm
Is this hard to do? Do I need to buy special equipment?
Raptor aura is enough to intimidate most would be thieves. AFAIK, there are only 2 lock config options - remote lock/unlock and I forget the other. The former unlocks all doors when you unlock the front door by sensor, the latter unlocks all doors when you open the front door - both can be suppressed via menu.
If you have suspicions you didn’t lock the truck OR you may have inadvertently unlocked the truck with the somewhat portly remote, you can send a lock command via Ford Pass. The new remotes have a surprisingly long range.
dlbb
so cal
https://www.amazon.com/dp/B01F0GVBWY/?tag=fordraptorforum-20 easy usb to obd2. remember to install the drivers from the paper that comes with the elm
also forscan with an extended licence in a windows laptop.
so easy to me i did a truck via teamviewer with the owner turning the truck off and on and clicking ok.
couple of tips
save a back up of the as built for each module u change.
double and triple check before writing a module.
and not all forscan changes are for our trucks.
---------- Post added at 06:51 PM ---------- Previous post was at 06:46 PM ----------
secure idle makes it lock into park so it cannot be moved without the key
sniperm
sniperm
couple of tips
That sounds too complicated to me...haha
Some high-tech shizzle...
I think I'll just pass...
but Thanks!
dlbb
so cal
if you buy the elm and register on forscan and do the extended licance i can do it via team viewer. just a phone call and chat for 20-30 min lol. u turn off and on when asked and click ok.
quick program
autostart stop BCM 726-48-02 x0xx xxxx xxxx 1b
double honk delete BCM 726-41-02 xxx0 xxxx xxxx 2b
Secure Idle enable BCM 726-42-01 x1xx xxxx xxxx 3b
Panic Alarm BCM 726-37-01 xxxx xxx1 xxxx 4b
DRL - Parking Lights only (stock LEDs only) BCM 726-26-02 x1xx xxxx xxxx 5b
726-50-01 01xx 6b
autofold Mirrors - Lincoln Style (see desc in Notes) PDM 741-03-01 x84x xx 1p
PDM 741-12-01 Fxxx 2p
autofold Mirrors - Lincoln Style (see desc in Notes) DDM 740-03-01 x84x xx 1d
DDM 740-12-01 Fxxx 2d
quick boot with engine &trans temp IPC 720-07-01 xxxx xE5x 2xxx 1i with trailer brake
Fake engine noise disable ACM 727-01-01 xxxx x0xx xxxx 1acm
Stereo Extended Play APIM 7D0-01-01 xx*x xxxx xxxx 1apim Stereo Extended Play: A=off, 2=20mins, 3=30mins, 4=40mins, 5=50mins, 6=60mins (Sync 2 & Sync 3)
93,171
56,440
jumpcutter
