What are the specs on your wheels/tires? Are you leveled? Do you rub at all?
Great setup - looks killer!
Thanks a bunch The wheels are 20X9 Sota SSD's with a -12 offset. The tires are Nitto Ridge Grapplers 35X12.5. I have the RPG collars on for leveling but the I've had the wheels/tires on before the collars came in and I had zero rubbing.
What upfitter switch did you run your fogs to? And, are all 6 on the same switch?
Do you run them anytime your headlights are on?
The amber outer leds are tied into the my marker lights so they run with the parking lights. I've got the middle set of fogs on Aux 1 and the outer 2 on with aux 2 and then all 3 on with aux 3 and the light bar is on aux 4.
