foo.c
If you go with a bigger wheel you could get the Wilwood big brake kit.
The biggest difference is in emergency stopping, downhill grades, etc. For example, the emergency stop when traffic in front of you comes to a halt all at once and with stock brakes you literally have to turn the wheel to one side to evade the vehicle in front of you due to brake fade and the truck not stopping fast enough. That is 99% cured. Downhill grades: I live in the mountains and with stock brakes there are many hills around me (ie: highway 52 southbound headed into NC) where the stock brake fade is ridiculous when they get warm.
For the average person that is normally very easy on their brakes, the difference in "feel" in daily driving is minimal with minimal brake pedal. But the times when you need them the most or if you are the type (like my wife) who waits to slow down for a stop until the very last second, etc. The difference is phenomenal.
I am a big fan of BBKs, and I know you're in the business of selling gear but you should keep expectations in check
If the OEM brakes are capable of locking the tires (which they are), then you will see no significant improvement in single brake event performance ie your emergency stopping scenario
A BBK could actually be slightly worse in emergency stopping distance if new setup (cheaply made but larger rotors, calipers, etc) weighs more than the OEM setup
Where you will see a difference is in repeated braking ie your mountain and offroad examples
You get BBKs for repeated braking where fade quickly becomes an issue
Ordered.
Did a road trip a couple days ago and really started to notice how bad OE is. Just sucks I have a 2500 mile drive this week and these wont be here before I leave.
Exactly. He sort of lost some credibility when he started talking about brake fade for a single braking event.
Also, I have personally seen brake fade in a single braking event in emergency stopping many times with stock parts, as have others. It IS possible, it DOES happen, more often than you might think. The R1 package also decreases stopping distance.
Also, when I speak of improvement in brake fade, that is real world, not just some marketing hype. I can point to several examples, but the reason brake fade is improved is because when you compare drilled and slotted rotors to stock OEM blanks in general, you improve brake fade, especially on long downhill grades.
Most of this is semantics, right, I looked at the link and saw rotors and pads so the only thing missing from a complete "kit" would be calipers
The point is the same - you're leading people astray if you tell them they will see significantly shorter differences in a single brake event, ie the emergency highway stop - they will not
If OEM brakes can lock tires (true for almost all modern cars), you are no better off on OEM vs $15K Brembo ceramic 6pot BBKs
It's just science - the tires, not the brakes, dictate the distance in this single brake event
To be complete, I'm sure you could come up with a scenario where this is wrong for the single brake event - ie coasting down a 8% grade for 1 minute - but I'm referring to what most of here assume is the situation, a true panic stop like an emergency highway stop or some kid darts in front of you
I'm in complete agreement with you on repeated emergency stops, fade, etc since here, the brakes ability to dissipate heat dictates distance
Do you, or whoever makes the kit, offer a refund and/or guarantee that stopping distances are shorter, or is it in writing anywhere
You said brake fade in a single event. That does not make sense. Brake fade down a long downhill grade makes perfect sense. Fade occurs when the the brakes get hot after multiple uses. If you're having problem in single braking events it is not because of fade.
I just think what you said was kind of misleading. While these might be great or even necessary for combating situations where brake fade can be an issue, emergency stopping is not one of them. Kind of really basic stuff here.
More to the point if you can actually prove these stop you faster I think you'd have a ton of customers.
If you want to help make that comparison happen, I am more than willing to get it done.
I am in DE if that's not too far away. Once I actually get my Raptor I would be happy to help with this kind of test if you're interested. I'll have an 802A SCREW so we'd just need another stock 802A SCREW for comparison.
