Transmission issue
ParkCity06
Utah
I have a 2020, and I am having an intermittent issue where my transmission doesn't shift into high gears. For example, I entered the freeway the other day, and after getting up to speed, I realized I was stuck at 4000 RPMs and in 4th gear--nor did my gear indicator next to the gauge cluster show any gears higher than 4th.
I always have to cycle the gear selector into neutral, then back into Drive to get the transmission to start shifting correctly.
Anyone else have this issue?
FordTechOne
Detroit
That means you’ve locked out the higher gears. There are buttons on the shifter; if you press the (-) button inadvertently, you will decrease the gear range by 1 each time. When you shift to neutral and then back to drive, it defaults back to all 10 gears.
P
ParkCity06
Utah
oh wow--haha--will check that out. thanks for this.
