raptor_qatar
You only need one jack under the rear diff and chock the front to be safe.
I launch with the rear locked but I also make sure I roll forward a bit to make sure it's fully locked. I do this also when engaging 4x4 before WOT with the Whipple.
I've even had the rear stay locked after pushing the knob back in and had to give her a some slight gas in reverse to unlock.
The warning comes on all the time?
I always do the same thing, never WOT from a standing start immediatly after engaging 4H. i used to do it while the car was moving, i put the gear on N and switch then one time i got a really bad clunk then when i switched to Drive i got kind of a rubbing or grinding noise, so i stopped after that.
as per the warning it comes on for a few seconds after i lock the diff then goes away i assume it just doesnt lock or do anything
---------- Post added at 09:03 AM ---------- Previous post was at 08:59 AM ----------
The rear diff is the only locking diff and shame on you for thinking you can do burn outs with the diff locked. Look under the back of the truck, the diff is the long. Round thing between the rear tires, at the center of the diameter of that piece is where your problem is. Good luck!
Well it made sense to me at the time XD you know lock the diff that way both tires spin = better burn out
was trying to top this, in all honsetly XD
https://www.youtube.com/watch?v=vJWavpPO3EY
