Gen2 Rear Wheel Locking Up
swimtexan
Dallas, TX
Take a look:
Summary:
4WD selector blinks and beeps
4WD selector will not move out of 2H
No 4A, 4L or 4H
Rear diff lock is off
Troubleshooting completed:
Neutral did not work, neither did switching back and forth through the different terrain modes to fix.
Disconnecting battery for 30mims didn't work and neither did resetting PCM with FORSCAN.
Wheels seem to skip on hard turns at low speeds and i checked the parking brake cable for any issues.
Specs:
1FTFW1RG9JFE46208
2018 with 56k miles
Stock suspension minus Deaver HD +3 springs
Antho
@swimtexan Def sounds like locker is engaged or a wheel sensor is freaking out the ABS. The flashing aux is a weird one. Did you get any DTC when you scan with Forscan?
swimtexan
swimtexan
Dallas, TX
I pulled the rear diff lock cable, no fix. It feels like the clutch grenaded itself and is locking out 4wd to protect itself. 1000019259.png
Antho
@swimtexan Do you have any DTC? Have you you tried resetting the TCCM? If you pull any DTC i can send you the pinpoint test. I also attached the 4WD operation/component Desc. I would start looking for a loose ground.
  • 2018.pdf
93,180
56,460
khunter
